450 HP Bet
Results 1 to 6 of 6
Thread: 450 HP Bet
    450 HP Bet
    Guys I need some help.
    A local Chevy Savvy guy, also a good friend, and one whom I seek advice from, has serious doubts that I'll be able to hit 450 hp on my build up.
    Even sarcastically enough to say that if I could get 450 hp out of my engine that he would GIVE me his race car; which is Chris' Pride and Joy... with his own personally built Chevy 350 in it. Ok so personally I have no interest in the race car, but still he's not believing that I can hit 450. The bet is on, and I don't back down without a fight.
    So here's the Topic:
    First I’d like to hear some bragging stories of 360s and 401s with HP figures, and how extensive you took each respective build. – to build up faith.
    Secondly I will post a little later what I have already done, and what I plan on doing to this engine. I will say that it is a Stock 1984 year 360. Stock Crank, Stock Rods, plans for Venolia Pistons. More details to come later, but I’d like to hear some experiences from you first.
    So lets hear some AMC’s with Bragging Rights!
    HP Torque And RPM’s where your readings were taken.
    Not going down without a fight
    -Mike
    Out to prove that AMC is still one of the best around!
    To start with, you'll want to invest in some forged rods and a forged crank.... or get a 401 (which has them stock).
    450 hp 360
    401 crank rods
    10-1 at least
    roller chain
    electric fuel pump
    roller rockers
    solid lifter cam and lifters
    under drive pulley
    oiling mods
    headers
    R4b or torker equivalent
    large 700cfm (at least) double pumper
    110 octane
    Ported heads (like the ones you already have)
    Remember to do these
    Good locks on the valves
    The right valve springs
    Balanced rotating assembly
    Basic rebuilding items
    You can do it, Really doesnt take that much with the right setup, Is it worth it to you to make this motor very very strong?
    450 hp 360
    Cheap for a race car
    don't forget the axles to support the power!
    Jan 2004
    Northern Minnesota
    2
    I wouldnt worry about it, it can be done i am quite sure of it. i have a 401 in an Ih pickup that i am quite certain is atleast 450. It desktop dynoed at about 475, and from the people i have talked to say that it is a relitively accurate figure. Here is a list of the things that i have done that i can think of off the top of my head
    4150 holley 750cfm carb
    offey 4bbl intake
    polished rods
    complete dynamic engine ballance
    double roller timing chain
    ported and polished dogleg exhaust
    ported and polished heads
    high compression hypereutectic pistons
    petronics ignigtor ignition
    45,000 volt coil
    8mm sparkplug wires
    custom cold air intake with single filter (would like dual cone filters)
    roller rockers
    performance cam (cant remember exact specs)
    3angle valve jpb
    aftermarket pushrods
    rebulit harmonic ballencer
    that is all i can think of right now, i think i might have got it all! feel free to ask if you have any questions, i would love to see you prove him wrong!
    1974 Ih 2x4
    a "fixed" 401+TF727 with shift kit+9"ford rearend= :)
    Thank you from BT Ultra tech
    Jan 2004
    Michiana
    457
    AMCs are an extremely easy 500HP build
    Tell your Chevy pal you'll take him up on his offer!
    You can then sell his cookie-cutter clone and buy an AMX!!!
    Anybody can bolt together a 500HP+ 390/401 for less than $5000 in NEW parts and machining.
    With used parts, maybe $3000, if you are starting with absolutely nothing.
    That's a GUARANTEE!!!
    Let your friend read this, I'll take his pink slip in about 9 seconds!!!
    (and that's with one 4bbl and no NOS)
    Nostalgia ProStock.
