The photographer for wedding called yestrday saying his jeep wont start. It is a 88 Sahara 4.2 automatic. This summer i installed a weber carb and it ran great since then up until a couple of weeks ago. It started to sputter while he was driving it . And then it was hard to start after sitting for a couple of days. I thought it may be the choke not working properly since it had started once it got cold. I checked that last week and it was workng properly and it looked like it could use a tune up. And he said he would take care of that. Then he called saturday and said it would not start at all. I asked if he did a tune up yet he saidno. So i went over tonight watched him do the tune up. and it still would not start. The old plugs were shot. and need replacing. When he pulled the out of cylinder 6 it seemed like there was fur on the plug. not sure if it came out like that or if he hit something in the engine bay.
Put all new plugs wires cap and rotor and went to start it and no go. Loosened the distr. adjusted it and got it started. It was running rough. Adjusted the timing. got it to run ok but it seemed to miss at 1100 rpm.
Got it to idle ok and stay idling by itself turned it off and tightend down the distr. Went to start it to take it for a test ride and it would not start agan. No matter what we did with the dist.
When we first got it running it seemed like there was excesive vacum in the carb...just by feeling it with my hand. Also it smells like it had a bad cat.
What should i look at?
Should I bypass the computer b/c of the weber carb?
Could the cat be partially clogged and causing these problems?
Do these motors have the vinyl timing chain like the older ones? should i check that?
I was also thinking of doing a compression test?
Thanks for your help
Paul
