U-bolt flip kits
Results 1 to 5 of 5
Thread: U-bolt flip kits
    Jan 2004
    RI
    430
    U-bolt flip kits
    Again, I'm and early Jeep guy, but like I said, there is that site and this would sell there.
    U-bolt flip kits for the Dana 27 and the Dana 44.
    Now I know that you can do Dana 44 flip kits by using Dodge hardware.
    Just wondering if this is profitable first of all, and probable second.
    Thanks.
    Erik
    Edit: I forgot to add the Dana 30 to the list.
    I like your thinking, i will ponders this when i have some machine time open
    Are you talking Wagoneer? Is it spring under the frame? If so, a Chev/Dodge RH drop D44 (or Ford highboy for LH drop) will bolt in. A touch wider than the pickup axle, but 7" of instalift in the front of mine. http://virtualjeep.com I got high steer arms that will clear the leaf springs w/o a spacer from http://www.ottindustries.com and used the stock Jeep tierods with longer centerlink and draglink center tube.
    I believe what he is looking for (and me also) is the parts to take the spring plates and put them on the axle tubes, and use square style u-bolts to go under the spring. This is used in a Spring Under Axle set up.
    I did that with my '84 J10's SUA axle with Ford Ubolt brackets. It's round to fit on the tube. (I took them off when I did the SOA swap)
