Some aftermarket manifold pics...
Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: Some aftermarket manifold pics...
    Thank you from BT Ultra tech
    Jan 2004
    Michiana
    457
    First one is NOT aftermarket, but is RARE, cast iron "Machine" 2 plane:
    Edelbrock "Performer"
    Edelbrock "R4B", AM dealer installed or OTC from AM or Edelbrock:
    (stronger below 6000 than the Torker)
    Edelbrock "Torker", strong in the upper Rs:
    Edelbrock "STR-11 CrossRam", AM dealer installed or OTC from AM or Edelbrock:
    Edelbrock "UR-18 UltraRam", with the "square bore" adapters:
    Edelbrock "UR-18 UltraRam", ready for Holley Dominators:
    Holley "Street Dominator" 2-plane:
    Holley "Dominator"(?) single-plane with F.I.:
    Offy "unk" single-plane:
    Offy "Dual-Port 360" 2x4 for Edelbrock/Carter AFB style carbs:
    Enderle mechanical F.I. that was on eBay a while back:
    Nostalgia ProStock.
    Oct 2003
    ohio
    13
    machine intake
    what is the part number on that machine 2 plane intake? I may have one of those and that would be exciting.
    Q
    Sep 2003
    Oak Harbor, WA 98277
    634
    whoo hooo
    now if only all of us could stumble across these.....
    Jan 2004
    Michiana
    457
    Rebel "Machine" intake manifold is...
    part # 319 9763
    Power range=3000-6500 RPM.
    Is better than R4B between 3000-5500 RPM.
    Nostalgia ProStock.
    Thank you from BT Gear Head
    Nov 2003
    249
    Where's the air-gap, and the torker2?
    In America, there is no natural, moral, or legal right, to obligate another person or persons, to your dept or desires.
    Jan 2004
    Michiana
    457
    Wiand "Channel Ram"
    See the spacers at the head/intake gask surface?
    They are for using with the Booth "ProStock" heads.
    Yet another style of Offy 360 degree equa-flow "Dual-Port"...
    An unknown origin AMC intake w.o divider between sides.
    Should be good at higher Rs than divided ones.
    If you have or see one, plz post part #.
    Some pics of the OTC Group19 Holley, List 3916-15, 950 CFM three barrel.
    Part #448 5730:
    Edelbrock Performer "Airgap":
    BDS blower kit for AMC:
    Nostalgia ProStock.
    Nov 2003
    249
    Hey Holeshot, Outstanding!!! Herman lewis and indy.
    Mar 2004
    Conway, AR
    100
    "An unknown origin AMC intake w.o divider between sides
    I have this manifold. It has no casting number. It does have "RD" (maybe Research & Development?) cast into the top of the runner behind the carb mounting pad. It has pre-70 bolt pattern.
    Hey rogue got a pic?
    sounds very interesting maybe a early R4B?
