...have been available for some time. Someone probably already posted on this, but I haven't been thru all those pages yet.
Nostalgia ProStock.
part #'s links?
Intresting .....
(these numbers came out of the 2001 catalog, probably more stuff for us by now)
Mopar Performance: (Tech Line 1-248-969-1690)
* DCC-4529678 Damper Attachment Pack 360 AMC (bolt/washers/key)
* DCC-5007057 Detroit Locker AMC 20 3.08:1 & up ratios $ 485.39
* DCC-5249536 Vibration Damper 1979-91 360 AMC V8 $ 58.99
* DCC-9017005 cam distributor drive gear $ 48.95
* DCC-8027352 distributor gear $ 71.95
* DCC-4529209 forged 2.5 & 4.0 rod, magna-fluxed and shot-peened, w/high strgth bolts
* DCC-4529611 forged 360 rod, magna-fluxed and shot-peened, w/high strength bolts
* DCC-4529856 ~91 V8 roller tappet set(matched pair w/guide bar)
* DCC-4529220 hydraulic individual tappet
* DCC-4529630 ~91 360 HD head gasket set
* DCC-4529631 ~91 360 intake gasket
* DCC-4529681 ~91 360 manifold attaching package (intake & exhaust)
* DCC-4529885 2.5 & 4.0 roller rockers, set of 2, hyd, mech, or roller
* DCC-5249009 2.5 & 4.0 dual idler gear drive
* DCC-4529607 360 std, performance rod bearing set (one rod)
* DCC-4529608 360 .001" under, performance rod bearing set (one rod)
* DCC-4529609 360 .002" under, performance rod bearing set (one rod)
* DCC-5249803 93~98 5.2/5.9 cast aluminum "Jeep" valve cvrs, gasks, screws, grommets
* DCC-4529634 360 engine gasket set
* DCC-5249907 ~91 5.9 cast piston, 4.11" bore flattop
* DCC-4876959 """"" rings
* DCC-4529594 V8 Race mechanical fuel pump
* DCC-4529687 Distributor cap & rotor kit
* DCC-4529684 Stock replacement electronic distributor
* DCC-4529632 Header gaskets
* DCC-4529613 Stainless intake valve, swirl polished, back-cut 3/8" stem
* DCC-4529614 Stainless exhaust valve, swirl polished, back-cut 3/8" stem
* DCC-4529629 Viton umbrella valve seals (not for dual springs)
* DCC-4529653 Hardened valve locks, 8 degree, single groove, 16
* DCC-4529616 Retainers for above 8 degree locks, single springs, 3/8" stem
* DCC-4876063 Chrome-silicon single w/damper valve springs, 1.78" inst.ht., .560" max
* DCC-4529636 Flywheel attach pack, 6 f'wheel blts, 6 clutch blts, pilot brg(needle)
* DCC-5249586 Jeep speed secrets, 350 pages, 4, 6, 8 cyl engines
Nostalgia ProStock.
