I've been on the amc forum, ifsja, and here looking for the right combo. I found a lot of great info on different parts of the build but not a specific combination. I like to know what's best and try to keep the build around $2500. I found a lot of good stuff on high rpm motors but not much on building one that pulls from the bottom.
I have a good block, crank and rods with a good set of heads. All will need machine work.The block will need to be bored, so I'll need pistons. The heads I'll polish and do a valve job.
This is in a FSJ, (4300lbs) with a TH400, 4.11's
any help is greatly appreciated.
tbarnes
