is there a drain plug on the dana 300 or do you have to drop the plate on the side of the transfer case...the fill plug is obvious i just dont see a drain plug.....
Yes it is on the bottom of the T case. There should be an access hole in the skid plate and an hex key or allan head wrench will fit.
84 CJ 7 304, Arb rear, 35 BFG,s with a 2 1/2 spring lift only and to many other mods to list, plus a offroad trailer also on 35 BFG,s
sweet ill take a look tonight then
a little late but i had to drill a hole in my skid plate to get to the plug of the 300 in my cj5 FYI
