MC-rear housing meaning the tail shaft? If so I think it's aluminum (I would have to double check tonight) cause every D-300 I have seen is cast iron.
Rollbar the Dana 300 has a aluminum tailshaft and the Dana 20 has a cast steel tailshaft. Paint and dirt can hide the material pretty well.
I almost 100% sure it's a D-300. 4L, 2wd, N, 4H on the shifter & it looks exactly like one. I must be loosing my mind after all these years. Pics tonight but Peach just called & said she went wheeling this morning B-4 work .
P.S. I had that backwards, the D-300 has the alum tail & the D-20 cast. Told U I was loosing it.
I meant the housing is cast, sorry, I didn't explain it right.Originally Posted by rollbar
I'll post some pics tonight as well as some numbers of the tranny. Like I said in my first post, back to first grade of Jeeps
Well it seems like I need to go to the funny farm or I was thinking of another tranny. Sorry to put U through this (moderator, delete if U want to) but it seems from getting some of the brown mud off the tranny is aluminum so it must be a T-4. Below are the T-case numbers & tranny numbers. Wow, did I have a memory lapse. I'm embarrassed , oh well
T-case-C-300-15-2 BW 2405
309007-4
5364854
S/N-384138
Tranny-RGKF23
1086
5359389
So I went here & it only shows the 176 4spd for that yr. but it's an aluminum housing.
http://jeep.off-road.com/jeep/articl....jsp?id=277032
If its a T4 it should have the no 13 -51 cast into it somewhere. Its supposed to be a weak trans and best swapped out.
84 CJ 7 304, Arb rear, 35 BFG,s with a 2 1/2 spring lift only and to many other mods to list, plus a offroad trailer also on 35 BFG,s
IT has some numbers cast in the front where the bell housing bolts to. I seen the number 23 & some others but couldn't make them out. I need younger eyes . I'll see if I can get them.
Nope it's a 176, looks like this. Plus I have two.
http://www.novak-adapt.com/knowledge/t176.htm
Thanks, I must be loosing my mind but U all helped me find it.
