I have a new in the box FRA410 flexplate specifically for the 1987 Jeep J10 and 1987-1990 Jeep Wrangler ... WITH ... the 258 I6 and the Mitsubishi-style mini starter (Chrysler).
The flexplate is drilled with both the large and small torque converter patterns, so it can be used with a 727, 998, 999 and 904 transmissions.
You could also use this flexplate on the Jeep 4.0L if you want to run a Jeep 727/999/904 behind it.
You could run this flexplate on any AMC V8 ... IF ... you have had your engine internally (neutral) balanced ... which is what I did on the 304 stroker.
You could also, use this flexplate with the 1972-1986 AMC & Jeep 232 & 258 I6 engines, and switch to the Mitsubishi mini-starter (4.0L style).
I am asking $35 for this. Thanks.
Here's a link to the product info : http://shop.oreillyauto.com/productd...tNumber=FRA410
