Page 9 of 16 FirstFirst ... 7891011 ... LastLast
Results 81 to 90 of 152
Thread: WALT'S 1968 AMC AMX
  1. #81
    Nov 2012
    SACRAMENTO CA
    124
    PUT THE GRILL AND BUMPER BACK ON I SEE I HAVE A POWER STEERING LEAK, WAIT FOR THE CARB.
  2. #82
    Nov 2012
    SACRAMENTO CA
    124
Size:  94.4 KBName:  IMG_1076.jpg
Size:  97.1 KBName:  IMG_1077.jpg
Size:  96.8 KBName:  IMG_1078.jpg
  3. #83
    Nov 2012
    SACRAMENTO CA
    124
    Extra parts that I had ordered then changed mind,or confused and ordered to many.Want to sell all together.All stainless 2 1/2 in.,red fittings 2 1/2 in. 2ea. black 3 1/2 to3 in.reducers.2 1/2 to 2 1/2 reducer.2 3/4 to 3 in. red reducer.3to2 1/2 90. 2 1/2 to 2/1/2 coupling. 3 in.by 3 ft. air inlet flex line. Heavy duty 3 1/2 hose clamp. Air filter 3 in. inlet. A few fittings were cut and not used. Asking $140.00 plus shipping for all.Thank you Walt 916-747-0051or e-mail Quickamx@sbcglobal.net . If you call 8 to 12 pacific time.
  4. #84
    Nov 2012
    SACRAMENTO CA
    124
  5. #85
    Feb 2007
    pei canada
    16
    WALT
    what did you use for timing retard system and where did you install blow off valve. Any miles on it yet or you tube videos so I can hear it.Thanks for posting your progress as was very informative.
    Goops
  6. #86
    Nov 2012
    SACRAMENTO CA
    124
    Goops I have a MSD 6 BTM and a Mallory distributor with centrifugal advance only not installed yet. Drove it about 4 mi. warm here 93 degrees .Idle was to high 1000 rpm. motor getting warmer then normal, called it a day. I did not check the timing yet I pulled of the vacuum advance [ maybe thats making it run warmer with less advance ?] Blow off valve is on the supercharger discharge going to the intercooler. It will be on you tube down the road. Will check things out tomorrow hope to make it to a car show Sunday.
  7. #87
    Nov 2012
    SACRAMENTO CA
    124
  8. #88
    Nov 2012
    SACRAMENTO CA
    124
    She runs but not good, stumbles we tried our best for a few days. We played with fuel psi, spark advance, the carb was all set up at AED.I called this guy thats mobil and is he good this stuff,used him to set up the motor after I had it built.He asked a million questions like cam,tire size,rear end gears,weight,compression ,then sets a new curve in the distributor using the distributor machine in the passenger seat of his van.He's coming by Tue. I'll let you know how it works out.
  9. #89
    Nov 2012
    SACRAMENTO CA
    124
    Well here's the latest ,the man came by and was here for 6 hrs.$ 230 later found things that we had wrong like fuel psi. gauge off ,and don't use a liquid filled one. The most important one was that distribtor had to much play due to a worn cam gear ,so thats my next fix. Yesterday I felt bad all this time, money, in this thing and its worse then when we started. We called AED for advice ,Jeff [what nice people] told us a few things to try, like going up on jet sizes .Wow did it come alive, still has a stumble around 3,000 RPM .Fell good now replace cam gear and get back getting the bugs out. Thinking about installing a bung in exhaust pipe for a combustion meter hook up. Anyone that can give advice please do so,thank you Walt.
  10. #90
    Nov 2012
    SACRAMENTO CA
    124
Tags for this Thread
