Starting my 4x8 frame build, couple questions - Page 7
Page 7 of 7 FirstFirst ... 567
Results 61 to 68 of 68
Thread: Starting my 4x8 frame build, couple questions
  1. #61
    Hard to say with the plasma cutter now giving an audible issue. A small air leak can sometimes sound like a crackle.
  2. #62
    Dec 2013
    Saskatchewan, Canada
    46
    It's not air, I never had the air hooked up.
    Ill try and see if I can borrow my friends pm45 one of these days, and see if the voltage acts the same.
  3. #63
    Dec 2013
    46
    Tom wants me to rma the pwm. He thinks that's the reason my voltage is acting up. So I'll give that a try.
  4. #64
    Dec 2013
    46
    I got my new (used) dell gx620 pc. Have it optimized and ready to go. Cant cut with it until I get my pwm from candcnc though.
    I will keep you updated
  5. #65
    Dec 2013
    46
    Finally got the new pwm in the mail. Everything seems to be working right. This is the first time I've been able to use thc. Happy happy happy.
  6. #66
    GREAT!
  7. #67
    Dec 2013
    46
    Built a computer desk and a water tank for draining the table. Tank is 18" tall x 24" wide 48" long. Holds 87 gal. Works well. I have two 1-1/2" drains in the table that tee into a 2" strainer, and 2" plumbing to the tank. It takes very little air pressure to fill the table back up.
    Name:  20140409_152618 (Medium).jpg
    Name:  20140409_152635 (Medium).jpg
  8. #68
    Dec 2013
    46
    Built the tank using the table. Cut slits for bending and for welding the inner supports for the top. Worked good, but it obviously does add a bit more welding than using a brake.
    Name:  20140406_212707 (Medium).jpg
    Name:  20140406_212731 (Medium).jpg
    Name:  20140406_212746 (Medium).jpg
