Great pic fuzz! I talk to Randy from time to time. He is a good guy and very knowledgable
I have heard myths of fuel pump eccentrics being put in backwards....... This is not true as they share the same chamfer on both sides and a oil groove 180 degrees from the keyway. I agree with Randy's statement on addressing thew gear wear. Although I have successfully ran a camshaft without a oil slot tunning around it I do believe that the higher the flow the easier it will be on the gears. Oil type also falls into place. If you run a 5w30 the shear of the oil may actually cause the wear as well.
