Edelbrock calls out a felpro part number I believe it is a std head gasket.
Thats intersting and I am sure that the standard felpro would be fine, athough I have heard rumors that felpro is developing a high performance upgrade gasket for AMC.Originally Posted by jeepsr4ever
I have built a turbo motor before, and felpro was used successfully with over 20lbs of non-intercooled boost, but from what I have read about the specs of the AMC ROL Ht gasket they might be better with an aluminum head? For the turbo motor I built there was a felpro upgrade head gasket available and it had the same features as the ROL HT.
My thinking is the ROL might be better suited for the occasional blast of Nitrous, might be better insurance over the standard felpro, but then again I would rather blow a head gasket then hole a piston
Edelbrock recommends that you use the FelPro 8266PTI gasket and the standard AMC torque spec.
I like that, though I read somewhere that it was only 65 Ft Lbs. and that made me a bit uncomfortableOriginally Posted by ol' school power
Nope, standard torque.
Just be sure to use hardened washers beneath the bolt heads.
Is it possible the port is small to fit early square ex manifolds? I am putting a set on an early 390 and the catalog doesnt mention having to change to dog leg. dont have a gasket to check or the manifold off car but i will try to see. let u guys know , thanks gary
GARY 68 390 AMX, AUTO, GO PAK
you will be changing to dog leg exhaust ports which will require diff headers.
all the Edelbrock aluminium heads use the AMC 70-later dog leg exhaust design
Member #377
I was just about sure of that, thank you for the info... gary
