header home Products Store Forums Chat Contact About Register search FAQ members groups profile Private messages Login/Out
ported vacuum switch (cto)
Post new topic   Reply to topic    AMC ROCKS! Forum Index -> Full Size Jeeps
View previous topic :: View next topic
Author Message
jarcher401
Swabie
Swabie
PostPosted: Sun Jan 31, 2010 3:12 am    Post subject: ported vacuum switch (cto) Reply with quote
While installing the 401 In my J10 I decided to replace all the censors and such and ran into a problem locating a ported vacuum switch or as the shop manual calls it a CTO (coolant temperature override). This is the 3 port vacuum switch that sends manifold vacuum under 160 degrees and then ported vacuum over 160 degrees to the distributor. There can also be a 2 port EGR/CTO switch that controls the EGR, not to confuse them. The "Standard" number is PVS10 which is discontinued for the AMC's. The only number I found on my old switch was Q23. Did a little digging in the Standard book and found one for a Ford application (PVS20) or (Duralast E941 switch interruptor) with the same specs (thread size and heat range). When it came in it also had Q23 designation on it. They should update the books for application. Just thought it might be of some interest to others.
Back to top
View user's profile Send private message
JERSEYJOE
Charter Member
PostPosted: Tue Mar 16, 2010 12:06 am    Post subject: PVS 10 Reply with quote
I JUST BOUGHT A PVS 10 AT MY PARTS STORE.
_________________
Back to top
jarcher401
Swabie
Swabie
PostPosted: Tue Mar 16, 2010 12:19 am    Post subject: Reply with quote
is there a Q23 stamped on it? My pvs10 and pvs20 were identical. What was your parts store and did they have a listing for the PVS10 or old stock?
Back to top
Display posts from previous:
Post new topic   Reply to topic    AMC ROCKS! Forum Index -> Full Size Jeeps All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by phpBB © 2001, 2005 phpBB Group
