header home Products Store Forums Chat Contact About Register search FAQ members groups profile Private messages Login/Out
Steering Question
Goto page Previous  1, 2
Post new topic   Reply to topic    AMC ROCKS! Forum Index -> Suspension
View previous topic :: View next topic
Author Message
msalaba
Junior wrench of the Forum
PostPosted: Tue Mar 30, 2010 3:42 pm    Post subject: Reply with quote
ironman_gq wrote:
they do sell sleeves that allow you to drill out the factory taper and drop in the sleeve to put the tie rod on top of the knuckle. I think they are designed for GM rod ends
tufcj wrote:
I do know the factory CJ ends were smaller than the Waggy. I had to have the pitman reamed to fit the Waggy end. A local machine shop charged me $10 to do it.
Hard to say if the tapers are the same diameter. I think you could buy a new Waggy tie rod for less than they're asking for that Chevy stuff.
iirc, all 1/2 ton (ford,chev,dodge,amc) tie rod ends have the same taper & diameter.
Same as one-tons all being the same. These have the same taper angle, but the min-max diameters are bigger and the taper length is longer.
I don't know about 3/4 ton I believe they were either 1/2 or 1 ton depending on vehicle and options.
The CJ ends have the same taper angle as 1/2 tons but have a smaller overall taper diameter. You pitman arm can be enlarged by using the correct angle reamer.
It's been years since modifying 1/2 ton gear. I deal mostly in 1 ton stuff now. Going by memory here, so some of this may be incorrect.
Dang CRS!!! Sad
A tie rod is easily constructed from DOM as well. 3/8" wall will work, but I prefer 1/2" wall for off road. Just make sure your ID is enough to cut the threads. (ID = OD - 2 x Wall Thickness) 1 1/2", 1/2" wall DOM tube is the correct ID to tap for 1 ton ends.
Most machine shops have taps to cut the threads.
Roll cage builders have mandrel benders if you need to clearance the tie rod around the diff.
Some like to use heim joints in steering systems. But, for on-road use, you would have to constantly check heim condition and make sure the bolts/holes are not wearing.
I use tie rod ends on my off-road rig and would not use anything else. I hit a stump right at the steering arm and bend the TRE shank about 15* and no breakage. (1-ton end) That really impressed me!
Good luck with you upgrade!
_________________
Back to top
View user's profile Send private message Send e-mail
northplainsdrifter
PostPosted: Wed Apr 28, 2010 2:35 pm    Post subject: Reply with quote
Finally got the CJ out of the gargare after the axle swap. For the drag link I ened up drilling a new hole in the knuckle and put in a heim joint. I like how it came out. I still have lots of little things to do, BUT IT MOVES!
_________________
It's a Jeep thing, Chrysler doesn't understand!
Back to top
Moderator
Moderator
PostPosted: Wed Apr 28, 2010 4:48 pm    Post subject: Reply with quote
You'll love the SOA. Best mod I ever did to my CJ.
Just looking at the front spring hangers. Did you rotate the knuckles enough to get the caster right? Looks like the pinion angle is good.
I didn't like having the front shackles below the frame on mine, they became rock catchers. In it's second incarnation, I moved the top of the shackles into the frame rail by welding in some tubes, which also lowered the back of the spring, and helped with caster and pinion angle.
Looking good. Got her going just in time to enjoy the summer sun. ok thumbs up ok thumbs up
_________________
1977 Jeep CJ7
Back to top
northplainsdrifter
PostPosted: Wed Apr 28, 2010 5:20 pm    Post subject: Reply with quote
I ground and moved the c's to give me about 6 degrees caster, this did allow better pinion angle. Because of the Scout front end, I had to outboard the front springs a bit otherwise I would have moved the shackles into the frame like you said. I used YJ springs in front and XJ in the rear. It's still a little too soft in back, I'll throw another leaf in hopes to stiffen it up. I still have lots a minor things to finish. So far I'm happy with it, it made it to the store and back for a 12 pack!
_________________
Back to top
Old Rugged Crosser
PostPosted: Wed Apr 28, 2010 5:50 pm    Post subject: Steering Reply with quote
Here is another good site to check out on this: http://www.pirate4x4.com/tech/billavista/Steering/Steering_Research/steeringresearch.htm salute to boucher!!
_________________
Larry The Old Rugged Crosser
in a Old Rugged Crosser 72 CJ-5
TAKE IT OUT AND PLAY WITH IT!
Play with it on Sunday
Pray for it on Monday
Heal it on Wednesday
Good thoughts now!
Back to top
Display posts from previous:
Post new topic   Reply to topic    AMC ROCKS! Forum Index -> Suspension All times are GMT
Page 2 of 2
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by phpBB © 2001, 2005 phpBB Group
