header home Products Store Forums Chat Contact About Register search FAQ members groups profile Private messages Login/Out
Cant get it to cut
Goto page 1, 2  Next
Post new topic   Reply to topic    AMC ROCKS! Forum Index -> General CNC plasma chat
View previous topic :: View next topic
Author Message
Brian1
Cook
Cook
PostPosted: Wed Apr 28, 2010 10:32 pm    Post subject: Cant get it to cut Reply with quote
I have been through all the setup steps in this forum and finally got some more time to spend trying to learn this system and I am having problems, I still havent cut a single piece on my machine.
Basically my problem is once I load the G-code and press start the torch moves into position, touches and then fires to pierce the material and then stops completly. It doesnt try to lift the torch or move, it just fires and then stops and stays in the same place. I have a piece of sheetmetal now with a ton of pierce points from trying different files and x/y locations, luckily it was scrap to begin with. No error codes or messages that I see and I have no idea where to go from here.
Using:
Hypertherm 1250 with DTHC card wired and hand torch
Z home tested good
MP3000-THC-HighRef post processor
MP3000-DTHC-UBOB2 Mach profile
Ground clamp directly connected to the workpiece/sheetmetal
Every once in a while when I load another code or reload the code it will say in Mach that the Fault error is "requested home axis home switch is active...please fix, then home." The z home is however not active/tripped (checked physically and in diagnostic screen) and I dont have any other home switches. This is after it moves into position and fires then stops.
Back to top
View user's profile Send private message
Site Admin
PostPosted: Wed Apr 28, 2010 11:00 pm    Post subject: Reply with quote
Does the Z axis come up for pierce height?
1. Windows XP?
2. Did you load the mp3000 into sheetcam using the wizard?
3. Under Config in Mach 3 in ports and pins whats you kernal speed?
4. DTHC online button in Mach 3 lit up?
5. Are you sure Z axis home switch is not used by any other home switch in Mach3?
_________________
I know AMC engines from oil pan to air cleaner. Performance and reliability are built every workday in our shop. We dont mess around with other makes, AMC only! If you have a question and cannot get through on our phone lines please PM me or email me personally at Jeepsr4ever@yahoo.com -Thanks
Nice hot one this year!
Back to top
View user's profile Send private message Send e-mail Visit poster's website AIM Address Yahoo Messenger MSN Messenger
Brian1
Cook
Cook
PostPosted: Thu Apr 29, 2010 4:25 pm    Post subject: Reply with quote
I havent looked closely at it but I dont think the torch height is coming up when it pierces.
1. yes. System is used only for the CNC
2. yes. (still have not got the license for sheetcam so it is the unliscened version but I dont think that is the problem?)
3. 45000hz
4. It blinks green
5. Fairly certain. The other home switches are turned off and in the diagnostics screen the only light that comes on when triggered is the z-home
Back to top
Site Admin
PostPosted: Thu Apr 29, 2010 5:33 pm    Post subject: Reply with quote
What its telling me is that you dont have the right pierce height in sheetcam. You are sure your Z axis home is working and activated? When you push the z axis upward does the Z home light up in the diagnostics tab in Mach 3?
_________________
Back to top
sadisticiron
Swabie
Swabie
PostPosted: Sat May 01, 2010 2:13 pm    Post subject: Reply with quote
email me at bobby@sadisticironworks.com and ill help u out. its easier then checking the forum
Back to top
sadisticiron
Swabie
Swabie
PostPosted: Sat May 01, 2010 2:14 pm    Post subject: Reply with quote
make sure u get the licence in to that helps alot
Back to top
Site Admin
PostPosted: Sat May 01, 2010 5:32 pm    Post subject: Reply with quote
It sounds like the torch isnt reading the arc ok to move. What plasma cutter are you using?
_________________
Back to top
Brian1
Cook
Cook
PostPosted: Tue May 04, 2010 1:57 am    Post subject: Reply with quote
Yes, z home lights up.
OK, I am going to have some time tomorrow to mess with it and on Wednesday. What do I need to check? I did enter a pierce height in sheetcam of around .125" if I remember right for the thin sheetmetal I am cutting.
Hypertherm 1250
Thanks, I will probably tomorrow.
Back to top
Site Admin
PostPosted: Tue May 04, 2010 3:00 am    Post subject: Reply with quote
Re-check your ground! If it doesnt get an arc ok to move your ground isnt hooked up. Also are you using a current transformer?
_________________
Back to top
Brian1
Cook
Cook
PostPosted: Tue May 04, 2010 4:08 am    Post subject: Reply with quote
Not using a current transformer. I take the arc ok from the board (screw terminal block) inside the 1250. With the hand torch hooked up maybe the arc ok connections are disabled, I already had to bypass the torch switch found on that same screw terminal block and splice into the hand torch wires.
Jim, is the arc ok on the terminal block disabled with the hand torch hooked up?
Back to top
Site Admin
PostPosted: Tue May 04, 2010 6:12 pm    Post subject: Reply with quote
In the 45 they are still active except torch on and off
_________________
Back to top
Brian1
Cook
Cook
PostPosted: Wed May 05, 2010 5:33 pm    Post subject: Reply with quote
OK I took the cover off the 1250 and got my meter out. I connected the 2 arc ok terminals on the thc card and the arc ok light came on in Mach. Now I connected my leads to the wires coming off the arc ok on the 1250 board and manually cut some metal while watching if the contacts closed and got nothing (no continuity), the arc ok signal is not getting to the thc card.
edit: arc ok seems to be working now from the 1250 but the torch will only cut about an 1" of travel manually by hand before shutting off. Still no arc ok signal in mach. Off to find the hypertherm manual somewhere...
Back to top
Display posts from previous:
Post new topic   Reply to topic    AMC ROCKS! Forum Index -> General CNC plasma chat All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by phpBB © 2001, 2005 phpBB Group
