| View previous topic :: View next topic |
| Author |
Message |
jeepsr4ever Site Admin
Joined: 14 Dec 2002 Posts: 9013 Location: New oil pump coming fast!
Posted: Wed May 05, 2010 5:38 pm Post subject: |
Hmmm it should be a very small signal! Is your arc ok hooked up near the torch on and off or on the digital side of the DTHC card...should be on the digital side. Only a current transformer uses the side near the torch on and off.
http://www.candcnc.com/PDF/THCSensor-REV14.pdf _________________ I know AMC engines from oil pan to air cleaner. Performance and reliability are built every workday in our shop. We dont mess around with other makes, AMC only! If you have a question and cannot get through on our phone lines please PM me or email me personally at Jeepsr4ever@yahoo.com -Thanks
Nice hot one this year! |
| Back to top |
Brian1 Cook
Posted: Wed May 05, 2010 6:37 pm Post subject: |
| Yes, it is on the Digital side. Whats puzzling me now is why I can even cut with the torch by hand without it turning off the arc after about 1" of cut. Good air, brand new consumables, good ground. It was working fine for the last project I used it for manually. |
| Back to top |
Posted: Wed May 05, 2010 7:51 pm Post subject: |
Give Tom a call he handles our electronics and he can probly troubleshoot you quicker!
903-364-2740 _________________ I know AMC engines from oil pan to air cleaner. Performance and reliability are built every workday in our shop. We dont mess around with other makes, AMC only! If you have a question and cannot get through on our phone lines please PM me or email me personally at Jeepsr4ever@yahoo.com -Thanks
| Back to top |
Brian1 Cook
Posted: Wed May 05, 2010 8:22 pm Post subject: |
Thanks, I think I may need to call hypertherm first. I think the relay (or whatever it is) is sticking or bad on the arc ok. Sometimes it is closed and sometimes it is open (both with the torch on and off) and sometimes 1 or both terminals is grounded to the case other times. I have unplugged the arc ok from the thc card and the continuity is still all over the map. I dont know what is going on, I just want to cut some parts  |
| Back to top |
Posted: Thu May 06, 2010 6:40 pm Post subject: |
Hmmm I wonder if you have the right wires. Hypertherm might want you to buy a Auto-interface relay. I dont think you need this. You could go 100% bullet proof and go with a current transformer. They are $12 ea and are easy to install. This gives you divided voltage for arc ok. _________________ I know AMC engines from oil pan to air cleaner. Performance and reliability are built every workday in our shop. We dont mess around with other makes, AMC only! If you have a question and cannot get through on our phone lines please PM me or email me personally at Jeepsr4ever@yahoo.com -Thanks
| Back to top |
