header home Products Store Forums Chat Contact About Register search FAQ members groups profile Private messages Login/Out
Can't get it to cut
Post new topic   Reply to topic    AMC ROCKS! Forum Index -> General CNC plasma chat
View previous topic :: View next topic
Author Message
nsmart
New to the forum
PostPosted: Sat Jul 03, 2010 2:08 am    Post subject: Can't get it to cut Reply with quote
I have the 4x4 gantry kit and have everything set up but it will not cut. When I load gcode into mach3 and try to hit run the gantry moves and the torch goes down to make contact with the metal. After making contact the torch fires and instead of moving to make the cut it just stays in the same place blowing a hole in the metal and that's it.
Does anyone have any idea what this could be? I have been trying to figure this out for days now.
Back to top
View user's profile Send private message
Site Admin
PostPosted: Sat Jul 03, 2010 12:50 pm    Post subject: Reply with quote
Do you get an error on the Mach 3 screen? Typically when this happens it means you have a bad ground. This is a safety feature in the system. Does your DTHC online button turn green and does your ARC OK button lightup?
_________________
I know AMC engines from oil pan to air cleaner. Performance and reliability are built every workday in our shop. We dont mess around with other makes, AMC only! If you have a question and cannot get through on our phone lines please PM me or email me personally at Jeepsr4ever@yahoo.com -Thanks
Nice hot one this year!
Back to top
View user's profile Send private message Send e-mail Visit poster's website AIM Address Yahoo Messenger MSN Messenger
nsmart
New to the forum
PostPosted: Sat Jul 03, 2010 5:25 pm    Post subject: Reply with quote
I am not getting a error message. The arc ok turns green but not the dthc. The dthc online does not light at all. The thc light flashes so I am not sure that is normal or if it should stay lit. If it is easier for you to call me my number is 214-232-3647.
Back to top
Site Admin
PostPosted: Sat Jul 03, 2010 7:16 pm    Post subject: Reply with quote
Calling you now
_________________
Back to top
nsmart
New to the forum
PostPosted: Sat Jul 03, 2010 8:46 pm    Post subject: Reply with quote
I tried recutting with the thc set higher and still not working. I was wrong about the arc ok signal. It does not light up either when the torch is on. I verified all my connections in the plasma cutter and they are all correct. The arc ok signal light will turn on if i jumper the wires on the dthc board in the plasma cutter but still no dthc light.
Back to top
Site Admin
PostPosted: Sun Jul 04, 2010 7:49 pm    Post subject: Reply with quote
Have you installed your Mach liscense file?
_________________
Back to top
nsmart
New to the forum
PostPosted: Mon Jul 05, 2010 4:53 am    Post subject: Reply with quote
yep!!!
Back to top
nsmart
New to the forum
PostPosted: Sat Jul 10, 2010 9:52 pm    Post subject: Reply with quote
I got the issue fixed with the computer not seeing the dthc with the help from tom. The cable you sent me was wrong and you had a gender changer connected to it. That was making the cable reversed from what the signals were supposed to be. I went and got a db9 extension cable from fry's electronics and that fixed that problem.
Now the problem is the cutting. The gantry will move to the cut spot and move down to pierce. It then pierces the metal and sits there with the torch on for a few seconds then turns the torch off. After that it will sit there some more time with the torch off and then it moves around the toolpath with the torch off. Then it moves to the next pierce point and does the exact same thing.
When the torch is on the arc ok light is on and the volts are showing also. I have the volts set at 117 per the hypertherm book and the torch volts are showing around 160 when it pierces. The amp box has zero in it at all times.
If I run the gcode with the thc off it does the same exact thing. I am not sure what the problem is but I am ready to get this table cutting!!
Back to top
Site Admin
PostPosted: Sun Jul 11, 2010 2:48 pm    Post subject: Reply with quote
Can you manually turn your torch on and it stays on? If it doesnt it is possible you have a bad consumable. Mach 3 is told not to move if you loose a ground or if the torch misfires like a consumable is worn.
_________________
Back to top
jimcolt
Moderator
Moderator
PostPosted: Wed Jul 14, 2010 4:00 pm    Post subject: Reply with quote
If he is reading arc voltage, then he has an adequate ground. Sounds to me as though there is no arc transfer (arc good) communication between the plasma and the control, therefore the torch just sits in place....if the arc voltage gets too high the plasma arc will extinguish....probably at around 165 or 170 volts. The voltage will keep rising if the torch sits in place....as the hole keeps getting bigger, making the effective arc length longer.
Jim Colt
Back to top
Display posts from previous:
Post new topic   Reply to topic    AMC ROCKS! Forum Index -> General CNC plasma chat All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by phpBB © 2001, 2005 phpBB Group
