| View previous topic :: View next topic |
| Author |
Message |
jeepsr4ever Site Admin
Joined: 14 Dec 2002 Posts: 8980 Location: New oil pump coming fast!
Posted: Sun Nov 20, 2005 8:40 pm Post subject: Part #534 Tri-flow oil filter relocation and dry sump pickup |
Their has been a major update to the #534..pictures very soon
#534 Tri-flow for AMC V8's replaces all dry sump pickups and allows the pickup tube (in the oil pan) hole to be plugged. Oil can be picked up by means of oil pan sump or other. No tapping of the block is needed (with single line) and this adaptor has provisions for running external coolers, oil filters, oil prelubers or/and oil volume meters or pressure sensors and it replaces entire oil filter adaptor. #534 comes with all holes premarked for easy plumbing.
Check our store for pricing
 _________________ I know AMC engines from oil pan to air cleaner. Performance and reliability are built every workday in our shop. We dont mess around with other makes, AMC only! If you have a question and cannot get through on our phone lines please PM me or email me personally at Jeepsr4ever@yahoo.com -Thanks
SHOP IS CLOSED TILL THE 3RD OF AUGUST!! GONE FISHING!! |
| Back to top |
Posted: Fri Sep 29, 2006 9:34 pm Post subject: |
UPDATE!!!
The #534 has gained in size and strength! It is now approx. 1.5" thick and has a upgraded pickup port making it the worlds best oil pump pickup and is used by the fastest AMC motors on the track as well as some serious offroaders. Check out the new port
We have also added a step hole for the oil return. Stock timing cover size is .55 and we have a .702 stepping down to a .625 so porting the timing cover is now a breeze as the #534 can act like a drill guide into the cover when it is bolted on. : This maximizes the gasket surface for PSI exceeding 120.
| Back to top |
