Results 1 to 2 of 2
Thread: NEW! 1968-1974 AMC V-8 Supercharger Kit
    Mar 2012
    United States
    Thumbs up NEW! 1968-1974 AMC V-8 Supercharger Kit
    Fits: 1968-74 290, 304, 343, 360, 390 and 401
    Horsepower Gain Using 91 Octane Fuel: 30%@ 4-5PSI / 50% @8PSI (8PSI requires optional carb & water injection)
    Supports Up To: 16psi & 800HP (with pulley change, HP carb, HP water injection, HP fuel pump & built motor
    4-5PSI Kit:
    $4,320.00+shipping (satin, manual steering). Includes all necessary hardware, satin self-contained P-1SC centrifugal supercharger, carburetor hat, ProFlo anti-surge system, electric high pressure/high volume 650HP rated fuel pump, boost referenced fuel pressure regulator, 8-rib s/c pulley & belt, V-pulley and belt for fan, alterator and water pump, HD mounting brackets w/spring loaded tensioner
    Installation Time: Approximately 1 day with normal hand tools
    Warranty: 1-year limited
    Availability: Approximately 2-weeks for satin or approximately 3-weeks for polished
    Payment Methods:
    Bank to bank transfers, check or PayPal
    Polished Finish +$590.00:
    s/c compressor, carburetor hat and brackets
    Power Steering Kit +540.00: ps pump with a remote reservoir, brackets, pulleys, belt and hoses
    Air Conditioning Kit +TBD:
    Requires Sanden A/C compressor4
    150HP 750 CFM Blow Through Carb +$1,050.00:
    No choke, specific jets, boost ref. power valve and pressure sealed throttle shafts
    Stage 1 Water Injection System + $790.00:
    5 gallon reservoir, industrial grade pump, pressure senstive switch (adjustable from 0 to 9 PSI), necessary plumbling and nozzle, fully automatic operation. Suports up to 800HP
    Stage 2 Water Injection System + $1050.00:
    Same as above except adjustalbe from 0 to 15 PSI. Supports up to 1200HP
    H.O. Fuel Pump +$150: Electric EFI fuel pump supports up to 800+HP (requires 1/2 fuel line both ways after 650HP)
    The Supercharger Store 314 W. Highway 8 Huachuca City, AZ 85616
    520-456-9706 (phone) 520-456-9868 (fax) bob@TheSuperchargerStore.comwww.TheSuperchargerStore.com
    Attached Images Attached Images
    Looks like it sticks out pretty far. Will it fit the small body cars (American, Gremlin, Hornet, Spirit, etc)?
Tags for this Thread
